My GPSMAP 62, 64, or 65 Series is in the Wrong Language
If your GPSMAP 62, 64, or 65 series handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
- Press the MENU key twice to open the main menu.
- Select
- Select
- Scroll to and select the second item in the menu.
- Scroll to and select the desired language.
