GPS Settings on the MARQ Collection (Gen 2)
The MARQ® Collection (Gen 2) watches support secondary satellite constellations in addition to GPS, such as GLONASS and GALILEO. Enabling a secondary satellite constellation allows for your watch to more quickly acquire a satellite fix, and can help maintain satellite connection in degraded signal situations where the environment may be a factor.
GPS Settings
NOTE: Enabling satellite options other than GPS Only will use additional battery power when using GPS on your watch.
  1. Hold MENU.
  2. Select Activities & Apps.
  3. Select an activity.
  4. Select (Activity Name) Settings.
  5. Select Satellites.
  6. Select a GPS setting:
    • Off: Disables satellite systems for the activity.
    • Use Default: Enables the watch to use the default system setting for satellites.
    • GPS Only: Uses only the GPS satellite system.
    • All Systems: Enables multiple satellite systems. Can offer increased performance in challenging environments and faster position acquisition than just GPS only.
    • All + Multi-Band: Enables multiple satellite systems on multiple frequency bands.
    • Auto Select: Enables the watch to use SatIQ™ technology to dynamically select the best multi-band system based on your environment.
    • UltraTrac™: Records track points and sensor data less frequently in order to preserve battery life.
