1. Select the desired video or photo in the Garmin dēzl™ app.
You can also delete a video or photo by touching and holding the video or photo and then touching the
Trash icon.
2. Select Connect to connect to Wi-Fi.
3. Trim the video as desired by touching and dragging the arrows on either side of the timeline. Skip this step for photos.
4. Touch the right arrow
and the app will prepare the video for export (keep the dezl app in the foreground during this process). This can take several minutes, depending on the length of the clip. When finished, it will display, Export Complete.
- Skip this step for photos.
- The video or photo will upload to the Garmin Vault when connected to an active Wi-Fi connection.
5. If desired, save the video or photo to your phone.
6. To view or share your video or photo:
NOTE: Video files export at a higher resolution (.mp4 file format). For more information on the types of video files the dash cam records, see: GLV Files on Garmin Dash Cams.
If you are experiencing poor resolution after exporting video files, ensure that the latest version of the Garmin dēzl™ app is running on your phone. All updates are downloaded via the App Store or Google Play Store.
