Garmin GLO Series LED Light Patterns
The Garmin GLO™ and GLO™ 2 receivers have two different LED indicators that can be used to display Bluetooth, charging, and GPS satellite status.
Bluetooth LED Patterns
The Bluetooth LED is Blue. The patterns displayed indicate the Bluetooth connection status.
Slow flashing blue: Searching for mobile devices
Rapid flashing blue: Pairing
Solid blue: Connected to mobile device
NOTE: When connected with an Android or Windows device, the LED will not turn solid until a compatible application is open and actively using the GLO.
Status LED Patterns
The Status LED can display two different colors: Orange (relates to the battery) and Green (relates to the GPS satellites). The patterns displayed can indicate charging and GPS signal status. If the device is powered off while charging, the LED indicators will not be illuminated at all.
Slow flashing orange: Charging, power connected
Solid orange: Battery charged, power connected
Orange off: Battery charged, power disconnected
Rapid flashing orange: Low battery
Alternating orange and green: Faulty battery or system error
Flashing green: Searching for GPS satellites
Solid green: GPS satellite fix
