My Rino 700 is in the Wrong Language
If your Rino® 700 outdoor handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
- Press
twice to open the main menu.
- Use the thumb stick to scroll to
, then press the thumb stick to select it.
- Select
- Scroll to and select the third item in the menu.
- Scroll to and select the desired language.
