Xero Windage Rail Out of Travel
Garmin intentionally limits the windage adjustment on the Xero A1i PRO bow sight from being set to a position where it would become potentially unsafe for the archer due to arrow/shelf contact.
If when setting up your Xero A1i PRO bow sight you find you are running out of right windage (for right-handed bows), please check your Center Shot measurement to ensure it is within the bow manufacturer's recommended specifications. If the Center shot measurement is out of spec and the arrow is too close to the riser, the bow's cam spacing should be adjusted to move the rest and sight windage proportionally.
NOTE: It is recommend all bow adjustments and setup be performed by a professional archery technician.
