Changing a 945 inReach Subscription Plan
An inReach subscription plan allows users to move up and down a tier within your current plan type, or change to a different plan type.
Moving up or down plan tiers can change the number of track points you can send, location requests, or available tracking interval. Additionally, you can switch your subscription plan type between Personal Freedom and Annual plans, or change to a Professional Flex plan. Steps for both can be found below.
Important: Updating or changing inReach subscription plans may incur additional charges and may change your billing date/term. Review your plan type before making changes. When changing from Freedom to Annual Contract Plans there is no Annual Program Fee. For more information about plans, see Related.
Select an option below for steps.
Changing Subscription Plan Tiers
- Log in to the Garmin Explore Website
- Select Plans & Devices
- Select Edit
- Select Change Plan
- Select a new plan from the list by clicking the bullet next to the desired plan
- For more information, you can click Plan Details and ?
- Select Continue
Switching Between Freedom and Annual Plans
- Select Edit
- Select the area at the bottom indicated here
- Information about the new type of subscription is listed
- Select either Change to Contract/Freedom Plans
- Select the new plan type
- Select Continue
Always sync your inReach after making changes to your account. Many changes will not be reflected on the device until it has been synced. For information on syncing, see Related.
Looking For Something Else?
- Trying to transfer your current inReach service to a different inReach device? See - Transferring Existing inReach Service to a New or Replacement Device
- Wanting to suspend or reactivate your inReach service? See - Suspending an inReach Subscription Service Plan or Reactivating a Suspended inReach Device
- Looking to cancel your inReach service? See - Canceling an inReach Subscription Service Plan
