Garmin Catalyst Glossary of Terms
See Below for a Glossary of Terms Used with the Garmin Catalyst™ Driving Performance Optimizer
  • Accel. Time
    • The total acceleration time in a segment
  • Apex
    • The point in your racing line closest to the inside of a curve
  • Best Seq. Var.
    • This statistic relates to your consistency
    • The data shows your variability in lap times over your best 3 back-to-back laps during the recorded drive session
  • Decel. Time
    • The total deceleration time in a segment
  • Delta
    • Displays the time difference between the current lap and the best lap during the current session
    • You can adjust the Delta Timer to compare the difference in time between your current lap and your personal best, session best, today's best, or optimal lap
    • See Race Timer on the Garmin Catalyst for more info
  • Drive Session
    • When you start driving on a track, the device records detailed information about your driving statistics
    • The device stops recording information for a Drive Session when you select END
    • All of the data collected before you end recording comprises one Drive Session
    • See the owner's manual for more information about starting a Drive Session
    • See the videos below to learn more about reviewing Drive Sessions
Reviewing the Session Summary Page
Reviewing Session Videos
  • G-G Diagram
    • A G-G diagram is a graphical representation of the G-forces on a vehicle in the lateral and longitudinal dimensions.
    • It is used to evaluate the performance of a vehicle’s braking, acceleration, and cornering, and the transitions between each of those.
    • The Garmin Catalyst sets the min/max measurements based on the g-forces measured within the session. For example if the session reaches 1.5g, then that will be the outer ring/max. If the session exceeds 2g, then the outer ring may display as 2.5g. The inner rings will represent 1/3 and 2/3 of the maximum value shown.
  • Max. Accel.
    • The maximum acceleration value in a segment
  • Max. Decel.
    • The maximum deceleration value in a segment
  • Opportunities
    • During a drive session, the device analyzes your performance and records opportunities for improvement
    • Opportunities are coaching tips to help you decrease your lap time
    • The opportunities page enables you to review opportunities and offers tips for improvement
    • See the video below to learn more about opportunities
  • Optimal Lap
    • A lap synthesized from your best performances on each part of a given track
    • The device combines your position and speed on the track to show you your best possible lap statistics based on your measured performance
    • See the video below to learn more about the True Optimal Lap feature
  • Segments
    • Segments are small sections of a track
    • Each segment contains information about a specific maneuver, such as a turn or straight
    • Track segments are generated and defined by the device
    • See the video below to learn more about reviewing laps and segments
  • Straight Max
    • The measured speed at the fastest point on the straight
  • Top 3 Var.
    • The data shows your variability in lap times over your top 3 laps during the recorded drive session
  • Top 5 Var.
    • The data shows your variability in lap times over your top 5 laps during the recorded drive session
  • Track Configuration
    • Race tracks often have more than one configuration or racing area layout
    • These configurations can change in complexity or size
    • You should speak with the staff at a racing facility or track to determine which track configuration you are using
  • Track Out/Turn Rate
    • The rate at which you were turning while exiting the corner of a race track in degrees per second
  • Track Usage
    • The percentage of track used on a segment
  • Turn Entry
    • The measured speed at the turn entry in a segment
  • Turn Exit
    • The measured speed at the turn exit in a segment
  • Turn Minimum
    • The measured speed at the slowest point of the turn in a segment
  • Var.
    • The variability in lap time for a drive session
