Garmin Connect: Top Multisport Editing Tool FAQs
The Garmin Connect™ platform allows you to edit your multisport activity to adjust the time and distance of the entire activity, or each specific section, referred to as a leg. The following provides answers to frequently asked questions about editing multisport activities.
How Do I Edit A Multisport Activity?
You can edit a multisport activity in Garmin Connect web or in the Garmin Connect app. Select an option below for instructions:
Garmin Connect App Instructions
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Activities.
  4. Select Multisport.
  5. Select the activity you want to edit.
  6. Select the 3 dot icon in the upper right.
  7. Select Edit Activity.
  8. Select Edit Legs.
  9. Select the leg you want to edit.
  10. Update the leg Time or Distance information.
  11. Select Next at the bottom to edit other legs or select Done to save your changes.
Garmin Connect Web Instructions
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Activities from the navigation bar on the left.
  3. Select All Activities.
  4. Select the title of the multisport activity you want to edit.
  5. Select EditIcon to edit the activity.
  6. Select Edit Legs.
  7. Select the leg you want to edit from the drop down.
  8. Select Edit.
  9. Update the leg Time or Distance information.
  10. Select Next to edit other legs or select Save to save changes.
Why Do I Not See 'Edit Legs' on My Activity?
A multisport activity requires two or more legs to see the Edit Legs option when editing an activity. You will also not see an Edit Legs option if your multisport activity includes a child activity that cannot be trimmed. See FAQ Can I Crop or Trim a Timed Activity Using Garmin Connect? for more information on trimming activities.
Why Can I Not Delete a Leg of My Activity?
Multisport activities must have a minimum of two legs. Edit Legs will also be unavailable if only two legs remain.
Can I Divide An Activity Leg?
Yes, you can divide a single leg of an activity into multiple legs. When dividing the leg of a multisport activity, each leg duration must be less than the total time of the original leg.
Why Does My Multisport Activity Not Have a Trim Option?
Multisport activities cannot be edited or trimmed if they contain child activities that are not able to be trimmed (ex. Pool swim, Yoga, Cardio, Diving, Stopwatch). See FAQ Can I Crop or Trim a Timed Activity Using Garmin Connect? for more information about trimming activities in Garmin Connect.
Can I Restore my Edited Multisport Activity to its Original State?
Yes, you can restore the edited multisport activity to the original state by selecting Restore Original from the overflow menu in the top right of the Activity Details screen in the Garmin Connect app, or from the settings icon on the Activity Details screen of Garmin Connect web.
What Devices Are Compatible With Multisport Editing?
All devices featuring a Multisport or Triathlon activity profile are compatible with the multisport editing feature in Garmin Connect.
Related
