Getting Started With the Instinct Crossover Solar
If you are setting up a Instinct Crossover Solar for the first time, the following steps walk you through the process to help you get the most out of your new watch.
Setting up the Instinct Crossover Solar
When powering on the Instinct Crossover Solar for the first time, you will be prompted to configure your user setting and preferences on the watch. These settings can be changed at any time.
  1. Power on the Instinct Crossover Solar by holding LIGHT/CTRL.
    Learn About the Buttons
    Instinct Crossover Overview
    one instruction LIGHT/CTRL
    • Press to turn on the watch.
    • Press to turn the backlight on and off.
    • Hold to view the controls menu.
    two instruction GPS
    • Press to view the activity list and start or stop an activity.
    • Press to choose an option in a menu.
    • Hold to view GPS coordinates and save your location.
    three instruction BACK/SET
    • Press to return to the previous screen.
    • Press to record a lap, rest, or transition during a multisport activity.
    • Hold to view the watch face from any screen.
    four instruction DOWN/ABC
    • Press to scroll through the widget loop and menus.
    • Hold to view the altimeter, barometer, and compass (ABC) screen.
    five instruction UP/MENU
    • Hold to view the menu.
  2. Choose your language by scrolling through the list using UP and DOWN, press GPS to select the language.
  3. Pair the watch to your smartphone with the Garmin Connect app (optional).
    NOTE: Paring the watch with Garmin Connect will also register the watch.
    Learn More About Bluetooth Pairing
  4. Proceed through the onscreen prompts to select your preferences and user settings.
  5. Set up the Activity Menu by selecting your favorites (optional).
    Learn How to Set Your Favorite Activities
    1. Press GPS to access the Activity Menu.
    2. Use UP and DOWN to scroll through the list of available activity types.
    3. Press GPS to select each activity you wish to use.
    4. Select Done when finished.
Additional Resources
Want to learn more about your Instinct Crossover Solar? Visit the Welcome to the Instinct Crossover Solar page.
The video below walks through the steps to get started with your Instinct Crossover series watch.
