Changing Max Speed on dēzl™ and RV/Camper Devices
There are some instances where truck drivers are governed by speed.
You can Change Your Max Speed by Following These Steps:
1. From the home screen, select the Vehicle Profile Widget
2. Select the Vehicle Profile to edit
3. Select the Wrench Icon
4.Touch Max Speed
5. Enter the desired speed and touch Done
This will create a more realistic Estimated Time of Arrival.  Setting the max speed may also adjust the routing course and provide additional route suggestions.
