No Courses Near Message on a Garmin Approach
The No Courses Near or No Nearby Courses message means that something is preventing the golf courses from being used on your Approach® golf device. To fix this, the golf courses will need to be reloaded to the Approach device using the Garmin Express™ program.
Before getting started you will need the following:
Reinstalling Golf Courses
Watch the below video tutorial or follow the steps to reload your golf courses.
Steps for Reinstalling
  1. Connect your Approach device to the computer.
  2. Open the Garmin Express program.
  3. Select your Approach device.
    NOTE: If your Approach device is not listed, see - Adding a Garmin Product to Garmin Express.
  4. Select Course Details.
  5. Select Course Options.
    NOTE: If you only see an option to Install, see - Installing Updates to Your Approach.
  6. Select Reinstall for the region(s) that need reloaded.
  7. Select Continue.
  8. Once Garmin Express gives an Updates Complete message, safely eject the device from your computer before disconnecting it.
    • Windows: Press the Windows key + E, right-click the Garmin device and choose Eject. Once the device disappears, disconnect it from the computer.
    • Mac: Drag the device to the Trash or select the Finder and choose the Eject symbol next to the Garmin device. Once the device disappears, disconnect it from the Mac.
  9. Take the Approach device outdoors and start a round of golf. If a course(s) near you displays, your Approach device is now working properly.
