Pairing a Compatible Wind Sensors to a Watch with Applied Ballistics
Some Garmin® devices are able to pair with compatible wind sensors.1 The wind sensor must support BLE (Bluetooth® Low Energy) to pair with the watch.
Garmin Devices Compatible With Wind Sensors
D2™ Mach 1 Pro
Descent™ Mk2 | Descent™ Mk2S | Descent™ Mk2i
Descent™ Mk3 – 43 mm | Descent™ Mk3i – 43 mm | Descent™ Mk3i – 51 mm
Instinct® 2X Solar - Tactical Edition watch
MARQ® Commander (Gen 2) - Carbon Edition
tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition¹
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Delta - Solar Edition with Ballistics
Kestrel 5700AL Elite
Kestrel 5700AL-I ITAR Elite
Kestrel 5700AL-R Elite with prebuilt Ruger profiles
Kestrel 5700XAL X-hardware Elite
Kestrel 5700XALSF X-hardware Elite for SF
Kestrel 5700XEL ABX Elite (Military version)
Calypso Ultrasonic Portable Mini wind meter
Calypso Ultrasonic Portable Solar wind meter
Adding a Wind Sensor
Place your wind sensor in pairing mode, then follow the steps below on your watch.
NOTE: Calypso wind sensors can only pair to one device at a time.
Hold
Scroll down or select Settings.
Select Sensors & Accessories.
Select Add New+.
Select Other.
Locate and select the wind sensor.
Using the Wind Sensor with Applied Ballistics on Your Watch
Press
to open the activity list.
Select Applied Ballistics.
Press
Select Environment.
Choose Auto Update, or make changes to individual items.
Options: Wind Speed 1, Wind Speed 2, Wind Direction, Temperature, Amb/Stn Pressure, and Humidity.
Once paired, the wind sensor will show as connected in the sensor menu.
Having Problems Connecting?
If you are having an issue where the wind sensor will not pair, or was previously paired and has stopped working, try the following:
Ensure the sensor is not paired to another device.
Make sure that the sensor is charged.
Make sure that the software is up to date on both devices.
Power cycle the Garmin watch.
1 Software version 9.33 or higher is required on a tactix 7 series watch.
