Save Part of a Track Log as a Route
Your device has the ability to convert previously traveled trip data into a route for future use.
To Save a Segment of Your Trip/Track Log as a Route:
- Touch Apps
- Touch Tracks
- Touch the Active Tab
- Select the desired track
- Touch the menu button or wrench icon
- Touch Save As Trip
- Select preferred routing preference, either Start to Finish or Finish to Start
- Input the desired name for the new route
- Touch Done
Once calculated, you can touch Map to see the route that the unit created. You can touch Share to save the route to an SD memory card to share with other users. You may also edit the route to change the points on it or touch Go! to start the route you created from the trip log.
