Creating a New Bolt Profile for the Xero X1i
Bolt Profiles on the Xero® X1i crossbow scope allow you to create custom groups of aim points based on different bolt types and weights shot from the crossbow, up to a maximum of 10 bolt profiles. By creating profiles for hunting and practice bolts, different bolt types can be shot in the field by simply changing bolt profiles.
  1. Navigate to the Main Menu.
  2. Select PROFILE.
  3. Select ADD BOLT PROFILE.
  4. Enter a name for the bolt profile.
    TIP: Press the Up button or Down button to move through the menu.
  5. Press OK to enter a letter.
  6. Select Xero ICON Check Mark to confirm the name.
  7. Select YES to begin calibrating the bolt profile
From here, the scope instructs you to take a range to begin calibrating a new profile. This calibration is similar to the validation process when originally setting up the scope. The first range should be taken at 20 yards. Once this aim point is adjusted, you will have the option to complete an auto-calibration or manual calibration similar to the original setup of the scope. All instructions past this point will be provided by the scope.
NOTE: Any adjustments made when creating a new bolt profile should be electronic only (no manual adjustments).
Related
