Sending a Text Message Using a Rino 700, 750, 750t, or 755t
Text messages, known as Notes, can be sent from one compatible Rino® handheld to another compatible Rino handheld. In order for the notes to be sent properly, all Rino handhelds that are supposed to receive the message must be on the same Channel and Code.
Creating, Saving, and Sending Notes on a Rino 700 Outdoor Handheld
From the home screen, select Notes.
Select Send Note.
Select <New Note>.
Enter the note text.
Due to FCC regulations, you can enter a maximum of 13 characters in a note.
Select Done.
Select an option:
To send the note without saving it, select Send Note.
To save the note without sending it, select Save.
To save the note and send it, select Send and Save.
Creating, Saving, and Sending Notes on a Rino 750, 750t, or 755t Outdoor Handheld
From the app drawer, select Notes.
TIP: To open the notes app from the radio app, select
Select Send Note.
Select <New Note>.
Select
Select an option:
If there is no option to send notes, ensure that the device firmware is up to date by downloading and running the Garmin Express™ program.
