1. | You need WebUpdater installed on your computer first. If you already have WebUpdater installed, skip this step. | |||||||||
2. | Connect your Garmin to the computer with the appropriate USB cable. NOTE: Avoid using USB 3.0 ports when updating a collar. |
3. | WebUpdater will be launched during the installation process. If you already had WebUpdater installed, launch WebUpdater. TIP: Either double-click the WebUpdater shortcut on the desktop (if available), or search for WebUpdater in your Start menu. | |||||||||
4. | Select the desired Garmin device from the drop-down menu, or click Find Device if your device is not listed. Click Next. | ![]() | ||||||||
5. | WebUpdater will display the available updates. Click Next through the following pages to review the software release notes, software change history, and license agreement. | ![]() | ||||||||
6. | Check the box to agree to the license agreement terms, and then click Next to begin the update process. | ![]() | ||||||||
7. | Once the update starts, WebUpdater will display the current progress. | ![]() | ||||||||
8. | After installing the main update file, WebUpdater will prompt you to check for any additional updates. Click Next. | ![]() | ||||||||
9. | If additional updates are available, click the checkbox next to the desired updates and click Next to install them. Once complete, click Finish. If no additional updates were found, click Finish. |
10. | Once complete, disconnect your Garmin from the computer and power it on to make sure the software updates installed successfully. |
Updating a GLO Series Device With WebUpdater
Software for your GLO™ series sensor should be kept up-to-date to take advantage of improvements and bug fixes. Updates are free and easy to install.
To update your software, the Garmin WebUpdater program will need to be downloaded and installed. WebUpdater checks for software updates each time you connect your handheld to the computer and launch the program.
NOTE: The Garmin GLO series is not compatible with a Mac computer and will need to be updated with Windows
