No Wind Data
Wired and Wireless Wind Instruments
Garmin has both wired and wireless wind transducers. The wired transducers use a GND 10 box to transmit wind data to either a chartplotter or to a GNX Wind the wireless system. The wireless transducer pairs with either a single chartplotter or a GNX Wind and shares that data via the NMEA 2000 network to other devices.
Basic inspection and troubleshooting of the wind transducer
Inspect that the wind sensor is freely moving in the wind
Inspect for gWind transducer and mount for damage. Replace if broken
Remove any obstructions found
Inspect any cable connections related to the wind sensor and instrument display to ensure that there are no loose or chaffed wires or connectors
Power cycle the display, if connected to wirelessly pair to GNX or chartplotter
Power cycle the NMEA Network
Ensure the System Software is up to date
If it is a wireless model, clean the solar panel and allow to charge for 5 hours or try replacing the battery; gWind Wireless 2 Replacement batteries
When troubleshooting the wind sensor, set it to apparent wind angle/speed (AWA/AWS)
The GND 10 Status lights
The GND 10 has a three status lights next to each of the ports, NMEA 2000, Nexus, and the USB. See GND 10 Status or Blink Codes for more information and steps to perform to resolve the issue. If there is no light on the NMEA 2000 status light, see NMEA 2000 Troubleshooting for steps to perform. If the Nexus port has no lights or is not transmitting data, see Troubleshooting the Mast Cable.
gWind Wireless 2
The gWind Wireless 2 connects wirelessly to a compatible chartplotter or GNX Wind and is identified by the blue support shaft.
Environmental sources that create issues for the wireless connection
The gWind Wireless 2 wind sensor maximum distance is 50ft away from the paired device
Lacking a clear line-of-sight between the devices
Obstructions, interior mounting locations, Biminis, fiberglass, metal, wood, carbon fiber, Kevlar, sails, masts, booms, rigging, and Instrument pods can have adverse effect to signal strength
Disruption by VHF, cell phone, other Wi-Fi systems, and electromagnetic interference
No Wind Data on a GNX Wind
GNX Wind
Ensure power is coming from the NMEA 2000 to the GNX Wind instrument
Ensure the max distance is less than fifty feet
There is an unobstructed line-of-sight between the gWind Wireless 2 transducer and the GNX Wind instrument or chartplotter
Verify the GNX Wind wireless connection is on
See NMEA 2000 Troubleshooting for specific directions on troubleshooting the NMEA 2000 network.
Turn on the Wireless function
If the wireless antenna symbol is missing from inside the wind rose on the GNX Wind, verify that the wireless feature is set to on. See manual for the GNX Wind, Finding the Owner's Manual for a Garmin Device
Check the RSSI strength
If the wireless symbol displays but no wind data is showing check the wireless RSSI signal strength found under menu item 4.3 SENS Configuration Settings.
The RSSI measures the wireless signal strength from the gWind Wireless 2 transducer to the GNX Wind and cannot measure between the gWind Wireless 2 transducers and the chartplotter.
Ranges between (1-100) the higher the number the better the signal strength
Optimal number is 70
Average number is 40
Anything lower than 25, is considered insufficient signal strength
If RSSI is below 25 or above and wind data is not present or not accurate
Look for and remove items that disrupt the wireless signal
VHF, cell phone, cell tower signals, Wi-Fi, and electromagnetic interference
Power cycle the GNX Wind - pair the gWind Wireless 2 and check RSSI levels
Power cycle the NEMA 2000 system - pair the gWind Wireless 2 and check RSSI levels
Remove the gWind Wireless 2 transducer from the mount and bring it to within 10ft of GNX Wind instrument - pair the gWind Wireless 2
Continue to monitor wind information and RSSI signal strength while slowly move the gWind Wireless 2 transducer away from the GNX wind instrument (Do not exceed fifty feet of separation and maintain a clear line of sight between the devices
No Wind Data on a Compatible Chartplotter
Check the distance and line-of-sight for obstructions between the chartplotter and gWind Wireless 2 transducer
Verify the chartplotter is paired to the gWind Wireless 2 transducer
Power cycle the chartplotter
Refer to the compatible GPSMAP or ECHOMAP owner’s manual for wireless pairing instructions. See Finding the Owner's Manual for a Garmin Device.
