How to Locate the Serial Number or Unit ID on an Automotive Device
Every Garmin automotive device will have a unique serial number and Unit ID number to identify it. The serial number is a combination of 8 to 9 letters or numbers, without spaces or dashes, externally printed on the device.
Serial Number
The location of the serial number varies by model.
Check the Following Possible Locations:
On the Back or Bottom of the Device:
If There is a Mounting Bracket on the Back of the Device, Remove it to Locate the Serial Number. See the Video Below for an Example of This:
Under the Magnetic Mounting Bracket:
Under the Battery Door or Inside the Battery Compartment:
On Devices with a Flip-Up Antenna on the Back, it is Under the Antenna:
On Garmin Dash Cam™ and Garmin Speak™ Devices, it is on the Bottom or Side of the Device:
On the Garmin PowerSwitch™, it is on the Side of the Device Under the Front Cover:
On dēzl™ Headsets, it is on the Inside of the Headset Band When it's Fully Extended:
On the Original Box, it is Printed Below one of the Barcodes:
In the Garmin Express Software for Mac or Windows Computers (After the Device has been Added):
- Open the Garmin Express software.
- The device can be connected or disconnected.
- Select your device on the Home screen.
- Select Tools & Content.
- The Serial Number is shown in the information displayed.
Unit ID
The Unit ID is a 10-digit number found internally when viewing the system information on the device. This can typically be found in the Device Settings on the About screen. There are a few common ways to access the Unit ID on Automotive devices.
To Find the Unit ID on Most Automotive GPS Devices:
- Select Settings
- Select Device or About Device
- Select About or Garmin Device Information
To Find the Unit ID on Most Dash Cam Devices:
- Select Settings
- Select System
- Select About
To Find the Unit ID of a device added to the dēzl™ App or Garmin Drive™ App:
- Open the dēzl app or Garmin Drive app
- Touch Settings (gear icon) in the top right
- If the Serial Number or Unit ID is not displayed, touch Finish Setup
- Touch Product Registration
If the steps above do not match your device, please reference your Owner's Manual for instructions.
