Steps to Enable Gps+Galileo Setting on the Forerunner 935
What is the Galileo Satellite System?
You can learn more about it here
How do I update the software on my watch?
Software updates will automatically be downloaded to Forerunner 935 when the watch is paired to a phone through the Garmin Connect App.  Updates may take a few days to download and installed on the watch.
To check for and install available software updates manually, you can use Garmin Express program on a personal computer.
Once Garmin Express is installed:
  1. Connect you Forerunner 935 to the computer
  2. Pair with Garmin Express (if necessary)
  3. Select Install when offered software version 9.60 (if not automatically downloaded)
  4. Safely disconnect the watch from the computer
  5. All updates to install on the watch
  6. Plug device back into the computer
  7. Select Install on GPS software 2.20
  8. Disconnect device and allow updates to install
My device is up to date. How do I enable this new feature?
After the updates are installed, you can do the following to enable GPS+Galileo:
  1. Press the Start/Stop key
  2. Select an Activity Profile
  3. Press and hold the Menu key
  4. Select Activity Settings
  5. Select GPS
  6. Select GPS+Galileo
GPS+Galileo will now be enabled on the Forerunner 935.
