Navigational Avoidances on Garmin Automotive Devices
Garmin devices have an Avoidance menu where you can select various options that will adjust how your device routes you. Items with a checkmark beside them will be avoided whenever possible.
NOTE: Custom road avoidances may need to be re-set after each map update. Custom area avoidances should remain accurate and intact after updating maps on the device.
To Locate the Avoidance Menu:
  1. Touch Settings
  2. Touch Navigation
  3. Touch Avoidances
    • Skip this step on some devices.
  4. Touch the desired Avoidance to enable it
Repeat the steps above to disable the checked Avoidance.
Available Avoidances:
NOTE: Not all avoidances listed below are available on all devices.
  • U-Turns – Avoids calculating routes that require a U-turn.
  • Highways or Motorways – Avoids highways, interstates, freeways, motorways, and other major routes.
  • Interstates – Avoids interstates.
  • Toll Roads or Tolls and Fees – Avoids toll roads and certain specified congestion zones.
  • Traffic – Avoids traffic if a quicker route is available.
    • Must be actively receiving traffic with the included traffic receiver.
    • Disabling traffic avoidance does not disable traffic alerts from appearing on the device; however, it will not take the reported traffic incident into account when calculating routes.
  • Ferries – Avoids routes that require a ferry crossing.
  • Carpool Lanes or Car Share Lanes – Avoids lanes designated specifically for carpooling, sometimes referred to as High-occupancy vehicle (HOV) lanes.
  • Unpaved Roads – avoids unpaved roads (gravel, dirt, etc.).
  • Custom Avoidances – Feature available on some devices that will allow you to select specific areas or lengths of road to avoid.
Note that devices will only avoid selected items when it is possible. For example, if you have U-Turns selected as an avoidance the device may still direct you to make a U-Turn if an alternate route is not available.
A Detailed Video Tutorial Discussing Route Settings is Available Below:
See the Video Tutorial for Further Details if Configuring your Device for the Fastest Routing:
