Traveling to Another Country with a Tread Device
The following links can help you get started if you plan to travel to a foreign country with your Tread® GPS navigator.
See Using the Manage Maps Feature in Garmin Express for the Tread for available mapping.
NOTE: Mapping is available for download in Garmin Express™ software. It is not necessary to purchase maps through the Garmin Website.
Verifying Maps Installed on the Tread:
Tip: After verifying a map region has been installed to the device, it helps to simulate a route in the region to make sure the map works and to become familiar with finding locations in the region before your trip. When searching for a location with an Anglicized name, use the local spellings of cities and street names rather than the Anglicized name, e.g. ‘Firenze’ instead of Florence or ‘Korinthos’ instead of Corinth.
To Find Locations and Simulate Routes:
- Searching for a Location in Another Country on an Automotive Device.
- For Tread®, Tread® - Base Edition GPS navigator, and Tread Textron: .
- For Arctic Cat G8 Display, Kawasaki RIDGE 8" Tread Display, Tread® - SxS Edition GPS navigator, Tread® - Overland Edition GPS navigator, and Tread® XL - Overland Edition GPS navigator: Simulating a Route on a Tread SxS Edition, Tread Overland Edition, and Tread XL Overland Edition.
- For Tread® XL - Baja Chase Edition GPS navigator and Tread® XL - Baja Race Edition GPS navigator: .
You can save the locations you plan to visit before you start your trip to save some time during your travels.
- For Tread, Tread Base Edition, and Tread Textron, see How to Search, Save, Edit, or Delete Locations on the Tread.
- For Arctic Cat G8 Display, Kawasaki RIDGE 8" Tread Display, Tread SxS Edition, Tread Overland Edition, and Tread XL Overland Edition, see How to Search, Save, Edit, or Delete Locations on the Tread SxS Edition, Tread Overland Edition, and Tread XL Overland Edition.
- For the Tread XL Baja Chase Edition, and Tread XL Baja Race Edition see .
The device may need some time to acquire satellites after arriving if traveling overseas or flying to the area where you plan to travel.
To Acquire Satellites:
Turn the device on and remain stationary in an area with a clear view of the sky
Allow 3 to 5 minutes for the device to acquire satellites.
It may be helpful to connect the device to power during this time to prevent it from entering “sleep” mode.
The Tread device will automatically use the correct map when it has acquired satellites. See the following FAQs for more information about this.
Visit the Support Center for device support during your travels.
