Garmin Force Trolling Motor Depth Adjustment Slips
If the depth adjustment on the Force Trolling Motor slips, there are a few things that can be done.
  1. It is possible the depth collet isn't tight enough. To fix this, partially stow then tighten the collet.
  2. The depth collet may not be keyed on the shaft correctly. To fix this, loosen the collet and completely slide it down the shaft. Verify that the little square notch in the collet matches the shaft (see image). NOTE: This step only applies to the original Force Trolling Motors, not the Kraken.
Depth Collet
