(2024) Service Bulletin 23036 Rev B: Approval of Part 23 GTX 345(R) Series ADS-B Software Version 3.41
PRODUCTS AFFECTED:
GTX 345(R) Series units installed using Part 23 ADS-B AML STC SA01714WI are affected.
CERTIFICATION AUTHORIZATION:
SA01714WI MDL Revision 22
COMPLIANCE:
Recommended: Compliance with Service Bulletin 23036 is recommended at the next scheduled maintenance interval.
PURPOSE:
This STC Service Bulletin provides notification of an update to STC SA01714WI, GTX 3X5(R) with ADS-B AML STC, MDL Revision 22.
MDL Revision 5 approves GTX 3X5 ADS-B Software Version 3.41:
- Corrected an issue described in Garmin Service Advisory 23009 that prevents the appearance of some traffic targets while the Basic Surface Situation Awareness (SURF) application is active.
- Corrected an issue where some 1090ES ADS-B and ADS-R surface targets may erroneously appear as directional.
- Removed transmittal of Non-Performing Emitter (NPE) traffic data from HSDB to other connected Garmin devices.
NOTE
This addresses a traffic display compatibility issue in some G3X™ installations as described in Garmin Service Advisory 23023. NPE data is still transmitted using Connext® over wired serial interfaces and Bluetooth.
There are no new aircraft models or functionality being added to the STC SA01714WI.
WARRANTY INFORMATION:
This modification is warranty reimbursable with a deadline of October 31, 2023.
