The Move! Bar Does Not Appear to be Working on my Garmin Watch
The move bar will begin to fill on a device after one hour of inactivity and continue to fill for each additional 15 minutes of inactivity*. If for some reason the device's move bar is not filling up while being inactive, it could be due to the following:
  • The move bar is inactive one hour before and through your designated normal sleep times.
  • The device could be reading an incorrect sleep time, and is inactive. e.g., 10am-6pm instead of 10pm-6am
To confirm or change designated sleep times, visit the Garmin Connect Web on a computer or the Garmin Connect App. Here are the steps to verify sleep times:
Garmin Connect App:
  1. Open the Garmin Connect App on your mobile device
  2. Open the app menu: Select Garmin Devices
    • Android: Touch  (upper left hand corner)
    • iOS: Touch More (lower right hand corner)
  3. Select the Device
  4. Select User Settings
  5. Confirm your Bed Time and Wake Time
  6. Back out of Settings and allow your device to sync
Once the activity tracker is synced it should now work as intended.
Garmin Connect Web:
  1. Log into your Garmin Connect account
  2. Select
  3. Select the device
  5. Confirm your normal sleep time under Personal Information
Any changes made through the Connect website will require a sync of the device, with the computer, using Garmin Express.
*NOTE: The Forerunner 15 does not have a move bar and will simply display the word "Move!" after 1 hour of inactivity along with an audible beep.
