Chartplotters that can Control a Garmin Autopilot Without a GHC
After a certain software revision, chartplotters will gain access to setup and control Garmin Autopilots without needing a GHC™ autopilot controller present. The following chartplotters are capable of accessing this feature:
echoMAP™ CHIRP 5x chartplotters| echoMAP™ CHIRP 7x chartplotters | echoMAP™ CHIRP 9x chartplotters
ECHOMAP™ Plus 6x chartplotters| ECHOMAP™ Plus 7x chartplotters | ECHOMAP™ Plus 9x chartplotters
ECHOMAP™ UHD 6x chartplotters | ECHOMAP™ UHD 7x chartplotters | ECHOMAP™ UHD 9x chartplotters
ECHOMAP™ UHD2 6x chartplotters | ECHOMAP™ UHD2 7x chartplotters | ECHOMAP™ UHD2 9x chartplotters
ECHOMAP™ Ultra chartplotters
ECHOMAP™ Ultra 2 chartplotters
GPSMAP® 7x2 chartplotters | GPSMAP® 7x3 chartplotters | GPSMAP® 9x2 chartplotters | GPSMAP® 9x3 chartplotters
GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 chartplotters |GPSMAP® 12x3 chartplotters | GPSMAP® 16x3 chartplotters
GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters (added in software version 7.00)
GPSMAP® 8xxx chartplotters (added in software version 7.00)
- GPSMAP® 9xxx chartplotters
In order to enable the Autopilot feature use the following steps:
Select Home
Select Settings
Select System
Select Station Information
Select Autopilot Enabled
Turn Autopilot Enabled On
The entire echoMAP, echoMAP CHIRP, and ECHOMAP Plus series will automatically enable the Autopilot application once a Garmin Autopilot source is detected.
NOTE: It is still recommended to have a GHC present in the installation.
