Permissions Error when Sharing Video Files from VIRB Edit to Facebook
If you are receiving a permissions error when attempting to share a video from VIRB Edit to Facebook, you will need to export the desired video in VIRB Edit and then import that video to Facebook. The error usually occurs immediately after attempting to sign in to your Facebook account in the share video section of the program.
To export a video in VIRB Edit:
- Double-click the desired video in your Gallery
- Click Export
- Change the Media Settings and export location if needed
- Skip this step if you would like to keep the default settings
- Click Export
- Import the video file in to Facebook directly
- Refer to Facebook for instructions on importing video files directly
Note: A video that has just been imported, will not allow the Export option. Once the video is a part of your Gallery, it can be exported.
