What Is the Favorite Activities List on My Garmin Watch?
Many Garmin® watches feature the ability to add favorite activities to the activities list. Adding activities to your favorites list makes it easier find the activities you use most. See the steps below to add a favorite activity.
Benefits of Favorites
Having favorite activities allows you to quickly access the activities you do the most. See below for other benefits of adding favorite activities:
Single Favorite
  • Adding a single activity as a favorite will display only that activity when initially accessing the list of activities.
  • For outdoor activities, the watch will start to search for GPS for the activity when entering the activity list.
  • Sensors paired to the watch for that activity will automatically connect if turned on and in range.
Multiple Favorites
  • Multiple favorites are typically displayed at the top of the activities list to help separate them from other activities.
Adding a Favorite Activity
You can add or remove favorite activities at any time. The following directions will work for most watches. To see specific instructions for your watch, refer to your owner's manual
  1. Go to the settings menu on your device.
  2. Select Activities and Apps or Activities.
  3. Select Add
  4. Select an activity profile.
  5. You can move the activity up or down in your list of activities.
    NOTE: The list of favorite activities will appear at the top of the list.
  6. Press Watch with circle in top right corner START/STOP to confirm placement.
The activity has now been added to your list. Repeat the steps above to add more activities to your list.
Pinning a Favorite Activity
Some newer Garmin outdoor watches allow you to pin up to three of your favorite activities to the top of the apps and activities list for quick access. To learn more about pinning activities and to see if your device is compatible with this feature, see your owner's manual and search, “Pinning a Favorite Activity to the List.″
Related
