Unable to Pair a Collar to the Alpha 200 or Alpha 200i
If you are having problems pairing a dog tracking collar with an Alpha® 200 or Alpha® 200i dog tracking handheld, there are a few basic items you should check.
For steps on pairing your Alpha handheld with a dog tracking collar, see your owner's manual.
- The detachable antenna must be connected to the handheld.
Example
- Make sure you are releasing the button on the collar immediately after putting it in pairing mode. Starting the process is time-sensitive and holding the button too long will cause the collar to exit the pairing mode.
- If possible make sure that no other wireless items are in the area and broadcasting as they can cause interference.
- The collar must be compatible with the Alpha 200 handheld.
Compatible Collars- Alpha T 20
- Alpha TT 25
- T 5
- T 5 Mini
- T 5X
- TT™ 15
- TT™ 15 Mini
- TT™ 15X
- Update the software to your handheld and collar.
- Follow the steps in the linked article to apply updates to the Alpha 200 handheld and dog tracking collars - Installing Software Updates to Dog Tracking Handhelds and Compatible Collars
- Make sure that you do not have conflicting IDs by deactivating devices that are currently not in use.
- Follow the steps in the linked article to deactivate tracked devices - Activating and Deactivating Tracked Devices in Alpha 200i Groups
