Access Navionics Charts and Features on Lowrance Hook2/Hook Reveal Models
Plotter Software
NOTE: Plotter manufacturer’s latest software update is required.
Check your plotter’s software under Settings > System > About.
Current Chart Plotter/Sounder Software Update Versions
IMPORTANT: Do not use your Navionics® card to update your plotter software or have it in your plotter when you update.
Chart Layers
Set Chart Source to Navionics (Settings > Chart > Chart Source)
SonarChart™ OFF = Nautical Chart – official charting detail
SonarChart ON = SonarChart – high-definition bottom contour detail
Go to Menu > [More Options] > Chart Options > SonarChart
Chart Details (Full)
Dynamic Tides & Currents (On)
Easy View (On/Off) - Text and icon magnifying feature
[Navionics] Community Edits (On/Off)
Menu > [More Options] > Chart Options:
SonarChart Density – density of contours displayed on SonarChart layer
Fishing Range – select a range of depths to fill with a different color
Shallow Water Highlight – highlights shallow water between 0 and up to 10m/30ft
Transparency – Min = Full Overlay (harder to see chart details) or Max = Less Overlay (harder to see overlay details)
Minimum Depth – Considered safety depth when creating SonarChart Live
SonarChart Live Tide Correction – Found from Home screen Settings > System > Chart > SonarChart Live Tide Correction (On) – Allows contours to be adjusted according to nearest tide station for tidal waters
