If you are following a course or using the navigation features to route to a location, ClimbPro is considered to be "Tethered" to that path. ClimbPro knows the whole path you will be taking and will look along it to identify climbs and pass them to the Climb Examiner for processing. The Climb Examiner will determine if those upcoming climbs match your specified Climb settings. ClimbPro will not look outside of the navigation path for additional climbs.
If you are not navigating, this is considered to be a "Free" climb detection. The Edge passes your direction of travel to a Predictive Engine that looks up the road for climbs meeting your specified Climb settings. If a climb is detected, the Edge will alert you and track your progress along the climb.
ClimbPro While Navigating
If you are doing one of the following, ClimbPro is considered to be in "Tethered" mode:
Following a course that has been loaded to or created on the Edge
Navigating to a specified location
ClimbPro uses the position and elevation data provided in the course file or the position and elevation data provided by the route using the loaded maps. To determine which climbs to include and activate, ClimbPro uses the Climb Detection setting you have enabled for your activity profile. Since ClimbPro knows the path you will be taking for the entirety of the course or route, it can provide additional information such as the total number of upcoming climbs and the distance to each climb.
ClimbPro Without Navigation
To support climb detection during a free ride supplementary maps have been added to the regional Garmin Cycling Maps. These additional maps include information about the climbs in a given network along with the terrain type (paved, unpaved or mixed) for each climb. In order for ClimbPro to work in "Free" mode, you must be using the latest version of Garmin Cycling Maps and have the ClimbPro maps enabled. The ClimbPro map version should match the Garmin Cycling Map version for the same region to trigger ClimbPro during a free ride.
Select
Select Activity Profiles.
Select a profile.
Select Navigation.
Select Map.
Select Configure Maps or Map Information.
Scroll down to view the list of ClimbPro maps enabled.
If the ClimbPro maps are not showing, refer to Managing Maps on Garmin Devices With Garmin Express to install the latest map updates for your device.
