Vehicle Profile Minimum Weight Requirement
If an automotive device is not taking the RV type of profile (height, weight, etc.) into consideration when calculating a route, this can indicate that the profile’s gross weight is below the minimum requirement.
The RV Profile requires a gross weight of at least 3.5 tons (7,000 pounds) in order to calculate RV appropriate routes. If set below this minimum, the device will not take the RV Profile into consideration when calculating a route.
See the device's Owner's Manual for instructions to change the vehicle profile.
