Getting Started With the Garmin Explore Website Map Page
The Map page of the Garmin Explore™ website is used to view tracking and location information of compatible devices, as well as creating and managing data like waypoints, tracks, etc.
NOTE: Date and time stamps will be displayed using the time zone your computer or mobile device is set to, which may differ from date and time provided by the handheld device.
This article provides a detailed explanation of the information provided on this page.
NOTE: For items mentioning to toggle visibility (i.e. eye/eyeball icons), this means clicking on the icon will change it from enabled to disabled, or vice versa.
Page Bar - Used to Navigate Between Different Pages
NOTE: If you are not a current inReach® satellite communicator subscriber, some options may not be present.
Home: Provides a summary of subscription, bill, and statistics
Map: Used to manage user data, view data and messages
Plan & Devices: View device information, manage primary collections, and change subscription information
Inbox: View and manage messages and message threads
Social: Manage and configure MapShare™ trip sharing page and social media settings
Account: Manage user and billing information. Can also send a test message to a device and adjust measurement units
Map Filters - Used to Alter Your View of Data
Bookmarks: Allows for saving a particular map view of data from a specific date range
Message Types: Able to hide or show different message types on the map
Locate: Location requests
Messages: Messages sent from the inReach communicator
Track Points: Track points sent from the inReach communicator
Navigation: Navigation to a waypoint
Reference Points: Reference point locations sent from an inReach SE®+ or inReach Explorer®+ satellite communicator
MapShare: MapShare™ link messages sent from the inReach communicator
Date & Time Range: Able to set the time-frame for which tracks can be viewed. Select from preset options or specify a custom date range. This does not affect the visibility of routes, courses, activities, or waypoints
Clear Filters: Removes all bookmarks, message types, and date/time filters on the map data
Map - Used for Trip Planning, Managing Data, and Viewing Messages on a Map
NOTES: To change the coordinate system or measurement units for the Map page, select the Account page > Units. The Overlander® GPS navigator is not compatible with courses. If courses are created from the Explore app or website and added to a collection, the Overlander® navigator will fail to sync any data until the course is deleted from the Explore account.
: Zoom in on the center of the map
: Zoom out from the center of the map
: Centers the map over the most recent track created by the device to MapShare™, the most recently imported track to the account, or the most recent message sent that included location.
: Change between map layers
Available mapping layers: Topo, OpenStreetMap, Aerial, and Road
: Select to place a waypoint on the map
: Select to start creating a new route
: Select to measure the distance between two or more points
: Imports GPX, KML, KMZ files
: Export data as a KML or GPX file
: Search for a city, address, trail, POI, etc
: A word bubble with options appears on the map when a waypoint, track, or other data has been selected
: Deletes the item from the library and collections
: Change which collections to include the item in
: Edit the item
: Tracks created in the field and sent via an inReach device, which will not sync to other devices by default.
: Tracks that can be synced to other devices. For more details, see - null.
