Using the Display on Tacx NEO Bikes
The Tacx® NEO Bike and Tacx® NEO Bike Plus smart trainers feature a built in display that can be conveniently customized during a ride.
Entering Customization Mode
To enter the mode to customize the display, click the control buttons on the inside of the right and left shifter at the same time:
right and left neo bike control buttons
Customization Options
While in customization mode pressing both buttons add the same time will cycle through the different fields. Once you have the field/setting you want to customize selected, select either the right or left button individually to cycle through the available options.
neo bike display data fields
Field/Setting Options
Simultaneous Left + Right ClicksDisplay Data
1Option to show resistance, slope, or power training mode. See table below for icon reference.
2Usually this icon will reflect the front gear, however in this mode it represents the fan speed between low, medium, or high.
3Power watts in current, or 3, 5, 10, or 30 second averaging.
4Speed in kilometers or miles per hour
Training Mode Icons
Training Mode Icons and Their Descriptions
SymbolModeDescription
resistance icon  ResistanceTraining is based on 20 possible resistance levels so you can ride without a specific target, such as a spin class. You can use the control buttons to change the resistance level.
slope icon on neo bike display SlopeTraining is based on a fixed incline so you can simulate gradients and hills. You can use the control buttons to set the incline and use the shifters to change gears.
power watts icon on neo bike display  Power Training is based on a fixed power output value so you can ride at a controlled and constant effort level. You can use the control buttons to set the value.
