My Approach X40 is in the Wrong Language
If your Approach X40 is set to the wrong language and you need to change it, the below instructions will guide you through changing the language on your watch.
Changing the Language
  1. Press the watch Key to enter the Menu
  2. Swipe to and select
  3. Swipe up 2 times
  4. Touch the screen
  5. Swipe up 3 times
  6. Touch the screen
  7. Swipe until you see your language
  8. Touch the screen
You have now changed the language on your Approach X40.
If you were unable to change the language on your watch using the steps above, select the option for Restoring Faults below and follow those steps to reset your watch. You will be prompted to select a language after the reset, during initial setup.
Restoring Defaults
null
Note: Any scorecards saved to the watch will remain on the watch after a factory reset.
null
