Customizing Your Activity Profile List in Garmin Connect
Many Garmin devices can update what activity profiles display on the watch in the Garmin Connect app and the Garmin Connect website. To see a list of available activity profiles on your watch, and to customize this list select one of the following options.
Garmin Connect app
NOTE: some devices have a limit to the number of activity profiles that will display on the watch at one time.
- Open the Garmin Connect app on your smartphone
- Access the menu
- Android: Touch
(upper left corner)
- iOS: Touch More (lower right corner)
- Android: Touch
- Select Garmin Devices
- Select your device
- Select Activity Options
- Select Edit (upper right corner)
- Select Plus or Minus to add or remove displayed activities
- Select Done
- Sync your device
Once the sync is complete the activity profiles on your device will be updated.
- Sign into Garmin Connect
- Click
in the top right corner
- Click Device Settings for your device
- Click Activity Options
- Check the activity profiles you want to display on the watch
- Click Save
- Sync your device
If your device does not offer the ability to customize the activity profile list in Garmin Connect, see your owner’s manual for instructions for customizing your watch.
