Adding and Using the Sleep Widget
The Sleep widget, found on compatible watches, will give you an at-a-glance timeline of your total sleep time, and sleep phases. When opening the widget you will see your bed and awakes times, along with a more detailed graph of your sleep phases.
Compatible Watches
    • Descent Mk2 series1
    • Enduro series
    • fenix 6 series1
    • Forerunner 745
    • Forerunner 945
    • Forerunner 945 LTE
    • MARQ Collection1
    • tactix Delta series1
    • Venu 2 series 2
Adding the Sleep Widget
  1. Hold Menu to enter the main menu
  2. Select Widgets
  3. Select Edit
  4. Select +Add
  5. Select Sleep
The Sleep widget is now in your widget loop.
1 The Sleep widget was added to the fenix 6 series, tactix Delta series and MARQ Collection with the release of software version 10.00, and to the Descent Mk2 series with the release of software version 8.00.
 2 On the Venu 2 series, it is not a widget, but rather a glance.
