Editing Waypoints and Routes on the Garmin Explore Website
Waypoints and routes can be edited at the Garmin Explore website, under the Map page. There is a 200-point limit per route. If there are a lot of points within the given route, it is recommended to split the route up, so each section is less than 200 points each.
Select an option below for detailed instructions.
Creating Waypoints using GPS Coordinates
  1. Log in at the Garmin Explore website
  2. Select the Map tab
  3. Select
  4. Place a waypoint on the map
  5. Enter the Lat/Lon
    White Word Bubble with Data Fields
    Optional: Enter elevation in the ft or m field
    Note: The Coordinate System can be changed under the Account tab, then the Units subtab.
  6. Click to save changes
Editing Existing Waypoints
  3. Select Waypoints
  4. Select a waypoint
  5. Click  to edit
  6. Enter the Lat/Lon
  7. Click to save changes
Editing Existing Routes
  3. Select Routes
  4. Select a route
  5. Click  to edit
  6. Points can be dragged to new locations or deleted by clicking directly on the route the point
Back to Top
