Selecting a Contact When Setting Up Incident Notifications
You are asked to select a contact shown on the zumo XT from your phone's phonebook when setting up incident notifications. The zumo XT will only display approximately 35 contacts. See the steps below to access more contacts to choose from for this feature.
Note: The zumo XT has a limit of 500 contacts. Having over 500 contacts may result in searches appearing differently or incomplete. For example: Some searches may not show the whole list or the list may not appear in alphanumeric order.
You must complete these tasks before you can set up an incident detection contact:
1. Connect your device to the Garmin Drive App
2. Select Settings
3. Select Wireless Networks and verify the Phone calls option is enabled for your phone
NOTE: You must be connected via Bluetooth to your phone and a headset to set up and use the incident notification feature
Setting up an Incident Contact:
1. Touch Settings
2. Touch the down arrow on the left, then touch Driver Assistance
3. Touch the down arrow, then touch Incident Notification
4. Touch Continue
5. If the desired contact is listed, select it and skip to step 7.
- If the contact is not listed, touch the magnifying glass in the upper left corner
6. Type the contact name
7. Touch the contact name, then touch Select
8. Touch Next
9. Type Your Name
10. Touch Next
11. Touch OK
12. Touch Save
