SD Memory Card Sizes for Automotive Devices
An automotive device can use the minimum/maximum (max) card size listed below under the device series.
Important Information:
  • A device may draw maps more slowly when using a card with a larger capacity if there are too many files and/or large files on the card.
  • A microSD card with at least 4 GB of space must be used when updating the maps on a device.
  • See Using a 64 GB microSD/SD Memory Card or Larger for devices below compatible with 64 GB microSD memory cards or larger.
  • Garmin Express™ will only install a map update to a memory card if there is not enough space on the internal storage of the device.
    • Maps cannot be moved from the device to a memory card manually.
  • Instructions on where to insert the microSD card can be found in your Device's Owner's Manual.
    • Some devices have 2 microSD card slots:  one for map data and one for dash cam storage.
  • microSD cards can be purchased from Garmin or other retailers.  Garmin offers the following microSD cards for purchase. 8 GB microSD Class 4 Card with SD Adapter, 16 GB microSD Class 10 Card with SD Adapter
  • NOTE: Garmin Dash Cam devices require a Class 10 card.
      • The card may need to be formatted to work in the device.
      • For instructions, go to the Support Center and enter the product name or the serial number of your device.
        • Once your device is selected enter “Formatting Camera SD Card" ” in the search field.
Select Your Device Series From This List:
Camper and RV GPS Navigators
Select the device below for camera microSD card compatibility and usage.
See null.
SD Memory Card Compatibility
ModelMaximum CapacityCard TypeClass
Camper 660LMT | RV 660LMT
Camper 760 | RV 760
Camper 770LMT-D | RV 770LMT-S
 32 GBmicroSDClass 2 to 10
Camper 780 & Traffic | RV 780 & Traffic   256 GBmicroSDClass 2 to 10
Camper 785 | RV 785 (Map SD card slot)  256 GBmicroSDClass 2 to 10
Camper 785 | RV 785 (Camera SD card slot) 64 GBmicroSDClass 10
Camper 795 | RV 795  256 GBmicroSDClass 4 to 10
CamperCam 795 with Built-in Dash Cam |
RVcam 795 RV Navigator with Built-in Dash Cam  (Map SD card slot)
RVcam 795 with Built-in Dash Cam (Camera SD card slot)
 256 GBmicroSDClass 10
Camper 890 | RV 890
Camper 1090 | RV 1090
Camper 895 | RV 895
Camper 1095 | RV 1095
Click Below for Video Instructions on Where to Insert your Device's microSD card:
Camper 795 and RV 795
Camper 890, RV 890, Camper 1090, and RV 1090
Camper 895, RV 895, Camper, 1095 and RV 1095
CamperCam 795 and RVcam 795
dēzl and dēzlCam GPS Navigators
dēzl™ 560 LMT GPS navigator
dēzl™ 570 LMT GPS navigator
dēzl™ 760 LMT GPS navigator
dēzl™ 770LMTHD GPS navigator
dēzl™ 580 LMT-S GPS navigator
dēzl™ 780LMT-S GPS navigator
 64 GBmicroSDClass 2 to 10
dēzlCam™ LMTHD and dēzlCam™ 785 LMT-S GPS navigators with camera (Map SD card slot)
 64 GBmicroSD
Class 2 to 10
dēzlCam™ LMTHD and dēzlCam™ 785 LMT-S GPS navigators with camera (Camera SD card slot)
 64 GBmicroSD
Class 10 for dēzlCam 785 LMT-S
Class 4 or higher for dēzlCam LMTHD
dēzl™ OTR500 GPS navigator
dēzl™ LGV700 and dēzl™ OTR700 GPS navigators
dēzl™ LGV800 and dēzl™ OTR800 GPS navigators
dēzl™ LGV1000 and dēzl™ OTR1000 GPS navigators
dēzl™ LGV610 and dēzl™ OTR610 GPS navigators
dēzl™ LGV710 and dēzl™ OTR710 GPS navigators
dēzl™ LGV810 and dēzl™ OTR810 GPS navigators
dēzl™ LGV1010 and dēzl™ OTR1010 GPS navigators
dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera (Map SD card slot)  256 GBmicroSDClass 4 to 10
dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera (Camera SD card slot  256 GBmicroSDClass 10
dēzlCam LGV710 and dēzlCam OTR710
dēzlCam 785 LMT-S and dēzl 780LMT-S
dēzlCam LMTHD
dēzl LGV610, dēzl OTR610, dēzl LGV710,and dēzl OTR710
dēzl LGV800, dēzl OTR800, dēzl LGV1000, and dēzl OTR1000
dēzl LGV810, dēzl OTR810, dēzl LGV1010, and dēzl OTR1010
Garmin Catalyst Driving Performance Optimizer
See null for more information.
ModelMinimum CapacityMaximum CapacityCard TypeClass
Garmin Catalyst™ Driving Performance Optimizer 32 GB256 GB256 GBClass 10
Garmin fleet management
Garmin fleet™ 770 | Garmin fleet™ 780 | Garmin fleet™ 790 management  32 GBmicroSDClass 2 to 10
Garmin Fleet 780, 790 (Camera SD card slot) 128 GBmicroSDClass 10
Garmin Dash Cam
Select the applicable FAQ below for camera microSD card compatibility and usage.
Using a 64 GB microSD/SD Memory Card or Larger for devices below compatible with 64 GB microSD/SD Memory Cards or larger.
null.
null.
Garmin Dash Cam™ 10
Garmin Dash Cam™ 20
4 GB 32 GBmicroSDClass 10
Garmin Dash Cam™ 30
Garmin Dash Cam™ 35
4 GB64 GBmicroSDClass 10
Garmin Dash Cam™ 45
Garmin Dash Cam™ 54
Garmin Dash Cam™ 55
Garmin Dash Cam™ 65W
4 GB 64 GBmicroSDClass 10
Garmin Dash Cam™ 46
Garmin Dash Cam™ 47
Garmin Dash Cam™ 56
Garmin Dash Cam™ 57
Garmin Dash Cam™ 66W
Garmin Dash Cam™ 67W
Garmin Dash Cam™ Mini
Garmin Dash Cam™ Mini 2
Garmin Dash Cam™ Live
Garmin Dash Cam™ Tandem
8 GB 512 GB
microSD
microSDHC
microSDXC
Class 10 or higher
Garmin Drive, Garmin DriveAssist, Garmin DriveCam, Garmin DriveLuxe, Garmin DriveSmart, Garmin DriveTrack
Garmin DriveAssist 50 and Garmin DriveAssist 51 GPS navigators with camera  (Camera SD card slot) - null.
null.
Garmin Drive™ 5 Garmin Drive™ 5LM | Garmin Drive™ 5LM EX | Garmin Drive™ 5LMT GPS navigators
Garmin Drive™ 6LM EX GPS navigator
Garmin Drive™ 40 GPS navigator
Garmin Drive™  50LM |  Garmin Drive™ 50LMT GPS navigators Garmin Drive™  51 | Garmin Drive™  51EX | Garmin Drive™  51LM GPS navigators
Garmin Drive™ 52 | Garmin Drive™ 52EX | Garmin Drive™ 52M | Garmin Drive™ 52MT | Garmin Drive™ 52MT-S GPS navigators
Garmin Drive™  60LM |  Garmin Drive™ 60LMT GPS navigators Garmin Drive™ 61 | Garmin Drive™ 61EX | Garmin Drive™ 61LMT-S GPS navigators
Garmin Drive™ 53 GPS navigator
Garmin Drive™ 53 & Traffic GPS navigator
Garmin Drive™ 53 & Live Traffic GPS navigator
256 GB microSDClass 2 to 10
Garmin DriveAssist™ 50 | Garmin DriveAssist™ 51 GPS navigators with camera (Map SD card slot) 32 GBmicroSDClass 2 to 10
Garmin DriveAssist™ 50 and Garmin DriveAssist™ 51 GPS navigators with camera  (Camera SD card slot) 64 GBmicroSDClass 10
Garmin DriveCam™ 76 GPS navigator with camera (Map SD card slot)256 GBmicroSDClass 4 to 10
Garmin DriveCam™ 76 GPS navigator with camera (Camera SD card slot)256 GBmicroSDClass 10
Garmin DriveLuxe™ 50LMTHD GPS navigator
Garmin DriveLuxe™ 51 GPS navigator
Garmin DriveSmart™ 5 GPS navigator
Garmin DriveSmart™ 6 GPS navigator
Garmin DriveSmart™ 7 GPS navigator
Garmin DriveSmart™ 50LMTHD GPS navigator
Garmin DriveSmart™ 60LMT GPS navigator
Garmin DriveSmart™ 70LMT GPS navigator
Garmin DriveSmart™ 71 EX GPS navigator
Garmin DriveSmart™ 51LMT-S GPS navigator
Garmin DriveSmart™ 55 & Traffic GPS navigator
Garmin DriveSmart™ 61LMT-S GPS navigator
Garmin DriveSmart™ 65 & Traffic GPS navigator
Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator 32 GBmicroSDClass 2 to 10
Garmin DriveSmart 65™ Traveler's Edition GPS navigator 32 GBmicroSDClass 2 to 10
Garmin DriveSmart™ 66MT-S GPS navigator
Garmin DriveSmart™ 76 GPS navigator
Garmin DriveSmart™ 66MT-S with Amazon Alexa GPS navigator
Garmin DriveSmart™ 76 with Amazon Alexa GPS navigator
Garmin DriveSmart™ 86 with Amazon Alexa GPS navigator
Garmin DriveTrack™ 70 GPS navigator
Garmin DriveTrack™ 71 GPS navigator
Garmin Drive 53
Garmin Drive 53 & Traffic
Garmin Drive 53 & Live Traffic
Garmin DriveCam 76
Most Other Garmin Automotive Devices
Garmin Speak Plus with Amazon Alexa With Built-in Dash Cam
Garmin Speak™ Plus4GB64 GBmicroSDClass 10
GVN 52 and GVN 53
GVN 52 and GVN 538 GBmicroSDClass 2 to 10
nüLink! LIVE
nüLink!® 1690 LIVE GPS navigator nüLink!® 1695 LIVE GPS navigator nüLink!® 2390 LIVE GPS navigator 32 GBmicroSDClass 2 to 10
nüvi
nüvi® 30 | nüvi® 40 | nüvi® 50 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 42 | nüvi® 44 | nüvi® 52 | nüvi® 54 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 55 | nüvi® 56 | nüvi® 65 | nüvi® 66 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 57 | nüvi® 58 | nüvi® 67 | nüvi® 68 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 200 | nüvi® 250 | nüvi® 260 | nüvi® 270 GPS navigators 32 GBSDClass 2 to 10
nüvi® 200W | nüvi® 250W | nüvi® 260W GPS navigators 32 GBSDClass 2 to 10
nüvi® 205 | nüvi® 255 | nüvi® 265 | nüvi® 275 GPS navigators 32 GBSD/microSDClass 2 to 10
nüvi® 255W | nüvi® 265W | nüvi® 285W GPS navigators 32 GBSD/microSDClass 2 to 10
nüvi® 465 GPS navigators 32 GBSDClass 2 to 10
nüvi® 500 | nüvi® 550 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 750 | nüvi® 760 | nüvi® 770 | nüvi® 780 GPS navigators 32 GBSDClass 2 to 10
nüvi® 755 | nüvi® 765 | nüvi® 775 | nüvi® 785 GPS navigators  32 GBSDClass 2 to 10
nüvi® 1100 | nüvi® 1200 | nüvi® 1250 | nüvi® 1260 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 1300 | nüvi® 1350 | nüvi® 1370 | nüvi® 1390 | nüvi® 1450 | nüvi® 1490 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2200 | nüvi® 2250 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2300 | nüvi® 2350 | nüvi® 2360 | nüvi® 2370 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2450 | nüvi® 2460 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2455 | nüvi® 2475 | nüvi® 2495 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2457 | nüvi® 2497 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2557 | nüvi® 2577 | nüvi® 2597 | nüvi® 2598 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2555 | nüvi® 2595 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2539 | nüvi® 2559 | nüvi® 2589 | nüvi® 2599 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2639 | nüvi® 2689 | nüvi® 2699 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 2757 | nüvi® 2797 | nüvi® 2798 | nüvi® 2789 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 3450 | nüvi® 3490 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 3550 | nüvi® 3590 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 3597 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi® 3750 | nüvi® 3760 | nüvi® 3790 GPS navigators 32 GBmicroSDClass 2 to 10
nüvi 295W, nüvi 850, nüvi 880, nüvi 855, and nüvi 885
nüvi® 295W GPS navigator 8 GBmicroSDClass 2 to 10
nüvi® 850 | nüvi® 880 | nüvi® 855 | nüvi® 885 GPS navigators 8 GBmicroSDClass 2 to 10
nüvi 350, nüvi 360, nüvi 370, nüvi 650, nüvi 660, nüvi 670, nüvi 680, and nüvi 5000 GPS Navigators
Devices in the nüvi® 300, 600, and 5000 series can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For more information, see the FAQ null.
nüvi® 350 | nüvi® 360 | nüvi® 370 GPS navigators 32 GBSDClass 2 to 10
nüvi® 650 | nüvi® 660 | nüvi® 670 | nüvi® 680 GPS navigators32 GBSDClass 2 to 10
nüvi® 5000 GPS navigators 8 GBSDClass 2 to 10
nüviCam™ LMTHD
null.
nüviCam™ LMTHD GPS navigator with camera (Camera SD card slot) 64 GBmicroSDClass 4 to 10
nüviCam™ LMTHD GPS navigator with camera (Map SD card slot)32 GBmicroSDClass 2 to 10
Video Instructions on Where to Insert the microSD card into the nüvi®Cam:
Overlander
64 GB cards and larger will often be labeled SDXC (Extended Capacity). SD, SDHC, and SDXC cards must be formatted as FAT32. See Overlander - Formatting the Memory Card.  If you are using a 64 GB card or higher and your computer does not allow you to format it as FAT32, it is recommended to use a 32 GB card instead.  See Using a 64 GB microSD/SD Memory Card or Larger.
Overlander® GPS navigator 64 GBmicroSDClass 10
StreetPilot
i-Series devices and the StreetPilot® c300 series do not support the SDHC (High Capacity) cards. All other devices support SDHC cards.
StreetPilot® c340 | StreetPilot® c320 | StreetPilot® c330 | StreetPilot® c340 GPS navigators 2 GBSDClass 2 to 10
StreetPilot® c510 | StreetPilot® c530 | StreetPilot® c550 | StreetPilot® c580 GPS navigators4 GBSDClass 2 to 10
StreetPilot®® i2 | StreetPilot® i3 | StreetPilot® i5 GPS navigators2 GBSDClass 2 to 10
StreetPilot® 7200 | StreetPilot® 7500 GPS navigators2 GBSDClass 2 to 10
Tread
Tread® - Base Edition GPS navigator 256 GBmicroSDClass 2 to 10
Tread® GPS navigator256 GBmicroSDClass 2 to 10
Tread® - Overland Edition GPS navigator256 GBmicroSDClass 2 to 10
Tread® - SxS Edition GPS navigator256 GBmicroSDClass 2 to 10
Tread® XL - Baja Chase Edition GPS navigator256 GBmicroSDClass 2 to 10
Tread® XL - Baja Race Edition GPS navigator256 GBmicroSDClass 2 to 10
Tread® XL - Overland Edition GPS navigator256 GBmicroSDClass 2 to 10
Click Below for Video Instructions on Where to Insert your Device's SD microSD card:
Tread and Tread - Base Edition GPS Navigators
Tread - Overland Edition and Tread XL - Overland Edition
Tread - SxS Edition
zūmo
64 GB cards or larger will often be labeled SDXC (Extended Capacity). SD, SDHC, and SDXC cards must be formatted as FAT32. If you are using a 64 GB card or larger and your computer does not allow you to format it as FAT32, it is recommended to use a 32 GB card instead.  See Using a 64 GB microSD/SD Memory Card.
zūmo® 220 GPS navigator
zūmo® 350 GPS navigator
zūmo® 390 GPS navigator
zūmo® 590 GPS navigator
zūmo® 660 GPS navigator
zūmo 395 | zūmo® 396 GPS navigators
zūmo® 595 GPS navigator
zūmo® 450 GPS navigator
zūmo® 550 GPS navigator
4 GBSDClass 2 to 10
zūmo® 665 GPS navigator 8 GBmicroSDClass 2 to 10
zūmo® XT GPS navigator256 GBmicroSDClass 2 to 10
zūmo® XT2 GPS navigator256 GBmicroSDClass 2 to 10
The zūmo XT and zūmo XT2 may not boot properly if there is a 64 GB card in the device and it hasn't been formatted. Put the memory card in the device after it is powered on and it will give a prompt to format it.
Video Instructions on Where to Insert the microSD card into the zūmo 396
Video Instructions on Where to Insert the microSD card into the zūmo XT
Video Instructions on Where to Insert the microSD card into the zūmo XT2
