Deleted Tracks Reappearing on inReach Account Map Page
If tracks from an inReach Explorer, SE+/Explorer+, or Mini that have been previously deleted are reappearing on the map tab of an inReach account, they are likely still stored on the handheld device and being transferred back to the account through inReach Sync. To prevent this from happening, the tracks will need to be deleted from the map tab and the inReach.
Note: Following these steps will permanently delete the track file and it will no longer be on the Explore account or the inReach device.
Select an option below for detailed instructions.
Deleting Tracks on the Explore Website
  1. Login at explore.garmin.com
  2. Select the Map tab
  3. Select Tracks, under Library
  4. Select the track to be deleted
  5. Click
After deleting the track from the map tab, next delete it from the inReach.
Deleting Tracks from an Explorer or SE+/Explorer+
  1. Select History
  2. Select the date the track was created
  3. Select Delete
Deleting Tracks from a Mini
  1. Select Tracking
  2. Press OK to see current tracking intervals
  3. Press OK again to start tracking
  4. Select Clear Log > Yes
  5. Select Stop Tracking
Once cleared, the tracks will no longer sync from the handheld unit back to the map tab. To confirm that the tracks have been permanently deleted, sync the unit with inReach Sync and then check the map tab of the inReach account.
