D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ Mk3 | Descent™ Mk3i
Enduro™ 2
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
How Do I Add Weather Locations to My Garmin Watch
Some newer watches allow you to add city weather locations from the weather widget. This feature is currently available on the following models:
Adding Weather Locations
Swipe or scroll to the Weather glance in your glance loop.
Select the Weather glance.
Press START/STOP or swipe from the right to the left.
Select Add Location.
Select Cities.
Select a nearby city or one of the following options:
Select Map.
Search Near.
Enter Search.
NOTE: A message may come up to use your phone as a keyboard. If you prefer to type in on the watch tap the message.
Around Me
Select the location to add it.
Changing Weather Locations
- Select either Current Location, or the location you wish to see.
My Device Is Not on the Compatibility List, But Still Gets Weather
If you have a device not included in the compatibility list, that device will have a weather setting in your Garmin Connect™ app. See steps below:
Open the Garmin Connect app.
Select More (bottom right).
Select Settings.
Select User Settings.
Set your Weather preferences.
NOTE: This settings will only correspond to the older watch that is not on the compatibility list.
