Approach® S70 | Approach® S70 - TaylorMade Edition
D2™ Air
D2™ Air X10
D2™ Mach 1 |D2™ Mach 1 Pro
Descent™ G1 | Descent™ G1 Solar | Decent™ G1 Solar - Ocean Edition
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
Descent™ Mk3 | Descent™ Mk3i
Enduro™
Enduro™ 2
Enduro™ 3
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix® E
Forerunner® 55
Forerunner® 165 | Forerunner® 165 Music
Forerunner® 245 | Forerunner® 245 Music
Forerunner® 255 | Forerunner® 255 Music | Forerunner® 255S | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner® 745
Forerunner® 945 | Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 6 | quatix® 6X Solar | quatix® 6 Titanium
quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Venu® 2 | Venu® 2S
Venu® 2 Plus
Venu® 3 | Venu® 3S
Venu® Sq 2 Music
vívoactive® 5
vívosmart® 5
Can Garmin Watches Broadcast Heart Rate Data?
Many Garmin® watches can broadcast heart rate, to verify compatibility and to find steps on how to broadcast refer to your owner's manual.
Many third-party apps and devices may require the heart rate to be broadcast over Bluetooth® to receive a signal. Any Garmin device or sensor that broadcasts over Bluetooth will also broadcast over ANT+® wireless protocol whenever you enable broadcasting. For devices compatible with Bluetooth broadcasting see the list below.
Garmin Heart Rate Straps That Broadcast Data via Bluetooth
In addition to the above watches, the following heart rate monitor straps can also broadcast their signal via Bluetooth which is a common feature needed to transmit this data to third-party apps.
HRM-Dual™ monitor
HRM-Fit™ monitor
HRM-Pro™ monitor
HRM-Pro™ Plus monitor
ANT+ Concurrent Connectivity
If you need to pair a sensor to more than one device, we recommend pairing using ANT+ on the Garmin device to leave the Bluetooth® Low Energy (BLE) channel open for other devices. For steps on how to set your sensor connection type, see your owner's manual.
For more information on compatibility and pairing with third-party apps, we recommend visiting the app's help pages or contacting the developer of the app.
