What Is In the Box Tacx NEO 2
The NEO 2 comes with all the parts and accessories needed to set up most bikes and begin indoor cycling training.  This FAQ will explain what parts are included in a NEO 2.
What's in the box?
  • NEO 2 trainer
  • Wheel block
  • Power Cord
  • NEO 2 Fitting Kit
  • 130 mm non-drive side quick release adapter  (preinstalled on trainer)
  • Quick release drive side adapter (preinstalled on trainer)
  • Type 1 Shimano/SRAM cassette body  (preinstalled on the trainer)
  • Rubber cap set- installed on trainer
What is included in the NEO 2 Fitting Kit?
A. Tacx Universal quick release skewer
B. 2.7 mm non-drive side spacer
Used for bikes with wider dropouts preventing proper bike installation on the trainer or for bikes with a disc brake that rub on the trainer.
C. 0.5 mm cassette hub spacer
Used if derailleur is touching trainer while in lowest gear. Installed on the axle behind the cassette body
D. 1 mm cassette hub spacer
Used when derailleur is touching trainer while in lowest gear. Installed on the axle behind the cassette body
E.Cassette spacer
Used when installing 8-10 speed cassettes on included cassette body. Installed behind the bike's cassette
neo2withletters
Replacement Part Numbers
Part DescriptionPart #
Wheel Block
North American Power Cord
Power Adapater
NEO 2 Fitting Kit
Tacx Universal Quick Release skewer
Rubber cap set
S2850.05
S1961.60
S2800.04
S2800.01
T1402
S0012
S2800.05
Liittyvä
