Forerunner 265 and 265S Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch.  The information in the tables below is presented to  help outline the conditions used to determine the estimated battery life specifications.  Usage beyond what is listed below may result in reduced battery life.  The information presented below is a reference-only guide for general use of the Forerunner 265 series of products.
The following usage assumptions were used to determine the estimated battery life for the Forerunner 265 Series.  Unless otherwise stated, all default software settings and configurations are assumed for battery life specifications.
Forerunner 265 Smarthwatch Mode Usage Assumptions - Default Display Configuration
Notifications per Day50
Number of Interactions per Day160
Device-Generated Alerts per Day (Move or Goal Alerts)2
Hours per Day Outside of Bluetooth Range of Phone1
Display Brightness and TimeoutDefault Settings
Watch FaceDefault
Number of Gestures per Day750
Average Number of Hours per Day Spend Outside5
Pulse Ox ModeDisabled by Default
Number of Minutes of Streaming Music0
Number of Timed Activities0
Battery Life
Up to 13 Days
Forerunner 265 Smarthwatch Mode Usage Assumptions - Display Always On Mode
Average Number of Hours per Day Spent Outside25
Watch FaceDefault
Average Number of Hours per Day Sleep38
Display TimeoutAlways on
 Battery Life
Up to 5 Days
Forerunner 265 Activity Mode Usage Assumptions
Number of Interactions per Hour10
Minutes of Interaction Post-Activity1
Number of Gestures per Hour25
Display Brightness & TimeoutDefault Settings
Assumed Temperature Range for Battery Life Specifications10C-40C
GPS-Only Mode without Music Battery Life
Up to 20 Hours
SatIQ (AutoSelect) Mode without Music Battery Life
Up to 16 Hours
All Systems + Multi-Band Mode without Music Battery Life
Up to 14 Hours
GPS-Only Mode with Music Battery Life
Up to 7 Hours
SatIQ (AutoSelect) Mode with Music Battery Life
Up to 6.5 Hours
All Systems + Multi-Band Mode with Music Battery Life
Up to 6 Hours
Forerunner 265S Smarthwatch Mode Usage Assumptions - Default Display Configuration
Watch FaceDefault
Battery Life
Up to 15 Days
Forerunner 265S Smarthwatch Mode Usage Assumptions - Display Always On Mode
Watch FaceDefault
Battery Life
Up to 5 Days
Forerunner 265S Activity Mode Usage Assumptions
Battery Life - GPS-Only Mode without Music
Up to 24 Hours
Battery Life - SatIQ (AutoSelect) Mode without Music
Up to 18 Hours
Battery Life - All Systems + Multi-Band Mode without Music
Up to 15 Hours
Battery Life - GPS-Only Mode with Music
Up to 7.5 Hours
Battery Life - SatIQ (AutoSelect) Mode with Music
Up to 7 Hours
Battery Life - All Systems + Multi-Band Mode with Music
Up to 6 Hours
1The “default” watch face is the watch face present on the device when it is taken out of the box.  The Forerunner 265 products are designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces.  The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
2 This device utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life.
3 The average number of hours per day of sleep is determined by the user-configured bed and wake times (a "sleep period"), not the number of hours the user actually sleeps. During this sleep period, the device's display is turned off. As a result, setting a shorter sleep period may decrease the battery life experienced in display always on mode.
