Alpha 300 or Alpha 300i Not Acquiring GPS Satellites
If your Alpha® 300 or Alpha® 300i dog tracking handheld is not acquiring satellites you should perform the following:
  1. If you are in the field and do not have access to perform a software update skip to step 3, otherwise continue with step 2.
  2. Perform a software update to ensure you are on the latest software available null
  3. If, after performing a software update and with a clear view of the sky, you are still unable to acquire a GPS satellite fix you can enable Multi-GNSS on your handheld by:
    1. Select Setup
    2. Select System
    3. Select Satellite
    4. Select Satellite System
    5. Select Multi-GNSS
  4. If you did not perform the software update in step 2, when you have access return to step 2 and perform a software update.
