I Do Not Immediately Receive Messages Sent to my inReach
A device with an active inReach subscription will check for messages based on the following:
  • Listen Interval of that model
  • After a message or track point has been sent
  • After requesting a weather forecast
  • By performing a manual mail check
When the device checks for messages, it must have a clear view of the sky and may take a few minutes for the message to be received.
Listen Intervals
Listen Intervals vary by device model and are outlined below.
GPSMAP 66i/86i/86sci and Montana 700i/750i
  • Listens for 10 minutes after sending a message
  • Checks for new messages every hour
inReach Explorer/SE
  • Default Listen Interval is 10 minutes
  • Listen Interval can be adjusted in Settings > Messages
inReach Explorer+/SE+
Note: Hourly Mail Checks were added in software version 4.2 as a system default. When a custom Listen Interval is set, Mail Checks will be performed every hour in addition to chosen Listen Interval.
inReach Mini
Manual Message Check
If you are waiting for a reply and do not want to wait for the next listen interval, a manual check can also be initiated on the device.
  1. Power on the GPSMAP 66i/86i/86sci
  2. Press the Menu button twice to reach the Main Menu
  3. Select inReach Utilities
  4. Select Check Mailbox
inReach Explorer or SE
  1. Power on the inReach
  2. Select Check
    Mail Check
  3. Select Check Now
    Check Now
inReach Explorer+ or SE+
  2. Select Check
    Mail Check
  3. Select Check Now
    Check Now
inReach Mini
  2. Press the down arrow until you reach the Mail Check screen
  3. Press OK
Montana 700i/750i
  1. Power on the Montana 700i/750i
  2. Select House Menu Icon to reach the Main Menu
  3. Select inReach
  4. Select inReach Utilities
  5. Select Check Mailbox
How inReach Messaging Works
inReach products use GPS satellites to find your position but send and receive messages through the Iridium satellite network. Depending on your location and your surroundings, messages can be sent or received in a matter of seconds, or it can take up to 30 minutes. In certain situations, it could take longer, especially if tracking is not actively being used.
For inReach devices to connect to the Iridium communication satellites, they need to be outside. There is only one Iridium satellite in the sky at a time. Each Iridium satellite passes by every 15 to 20 minutes, travels North-South, and rarely flies directly overhead.  An area surrounded by mountains, heavy tree cover, buildings, or other solid structures will increase the time it takes to send and receive messages or track points. Clouds have no effect on the communication between the Iridium satellites and the inReach device. The signal transmitted by the device may be too weak to reach the satellites through windows, so if you cannot connect to satellites indoors or in a vehicle, then you need to take the inReach outside.
When the inReach is used around a building or obstruction, it is best to be on the North or South side.
