Sending and Receiving Wirelessly With the GPSMAP 276Cx
Like many Garmin handhelds, the GPSMAP 276Cx can send and receive data wirelessly to other Garmin models using ANT+ or Bluetooth technology. You can share waypoints, routes, and track wirelessly. Before you can share data wirelessly, you must be within 3 m (10 ft.) of a compatible device.
Sending Data
- Power on the GPSMAP 276Cx
- Navigate to the Main Menu
- Navigate to either Route, Points, or Track
- Highlight the item you wish to send and press Menu
- Select Send Wirelessly
- The other compatible device must then be set to Receive
Receiving Data
- The other compatible device must be attempting to send data
- Press Menu
- Select Receive Wirelessly
