BaseStation Mode
Coordinating efforts requires the right tools. The BaseStation feature provides the ability to connect a Rino* series, Alpha series, Astro 900, Astro 430 or Astro 320 to a computer to view contacts and dogs on a larger display.
Before using BaseStation Mode having the following:
- Appropriate USB cable
- Download and install the latest BaseCamp software**
- Ensure the handheld is up to date using Garmin Express
To use BaseStation with a supported device:
- Turn on the device
- Enable BaseStation mode
- For instructions to enable BaseStation, see Enabling Basestation Mode below
- Connect the device to the computer
- On the device, select Yes to enable BaseCamp BaseStation mode
- In BaseCamp, wait for device to appear below the Devices heading
- Under the device name, select the BaseStation folder
- Select contacts or dogs to view them on the map
- Repeat steps 1-7 as needed for each device
Contacts from the device or devices are now viewable within BaseCamp.
Enabling BaseStation Mode
Rino series*:
- Press Setup
- Press System
- Press Interface
- Press BaseStation
Alpha:
- Press Setup
- Press System
- Press BaseCamp BaseStation
- Press Prompted
Astro 320, Astro 430 or Astro 900:
- Navigate to the Main Menu
- Select Setup
- Select System
- Select BaseCamp BaseStation
- Select Prompted
*Rino 700 model does not support BaseStation
**Tablets that meet the system requirements for BaseCamp and have a USB port can be used to run BaseStation mode.
