Improving the Battery Life of Garmin inReach Products
There are a few settings that can noticeably contribute to overall battery performance when using an inReach handheld.
Enabling or disabling settings, as well as adjusting timed intervals, will all affect the
expected battery life
. These settings should be adjusted based on usage before going out into the field.
NOTE: Before you address some of the functions that affect battery life, first ensure your inReach handheld firmware is up to date. See
Related
for steps.
Features and Conditions That Impact Battery Life
Backlight
Backlight use is a large contributor to battery drain. Having the backlight set at 100% will drain a lot of battery while the backlight is on. The manual setting for the backlight uses the least battery power. Having the backlight turned on when any button is pressed will use additional battery.
Connected to Phone
The amount battery life impacted by connecting to a smartphone is dependent on several different features. The more messages that are sent/received, notifications or times the handheld must search for the Bluetooth connection due to being taken out of range, will all impact how quickly the battery drains.
Android users may see some additional battery drain when connected with certain inReach handhelds as keeping the inReach connected requires the handhelds GPS to remain on.
View of the Sky
inReach handhelds are designed to be used outdoors. We suggest testing the device before you head out on your trip, but do so outside. If the device is powered on indoors, the battery will drain noticeably faster as the handheld will not be able to find the signal for sending/receiving messages or tracking points. Additionally, the handheld will have to try a lot harder to find a GPS signal.
Send Interval or Tracking
The Send Interval determines how often the inReach SE/SE+/Explorer/Explorer+, inReach Messenger, and inReach Mini series will send track points via the Iridium satellite network to your MapShare page. This feature can be changed in the device settings. Reducing how often the handheld sends these points will improve battery life.
The Tracking app in the GPSMAP 66i/86i/86sci and Montana 700i/750i performs this same function.
Log Interval or Recording Controls
The Log Interval sets the frequency at which the inReach SE+/Explorer/Explorer+ and inReach Mini logs your location and updates the track line on the map. Reducing how often the handheld records these track points will improve battery life.
The Activity Recording setting on the inReach Mini 2 determines how often a track point is recorded to the track log on the device. The Standard setting will use less battery than the High Detail setting.
The Recording Controls App in the GPSMAP 66i/86i/86sci and Montana 700i/750i determines how often a track point is recorded to the track log on the device. The GPS is always on whether a track point is recorded or not so, there will be no real improvement in battery performance by reducing how often track points are recorded.
Low Power Modes: Extended Tracking or Expedition Mode
NOTE: Hardware and software improvements have eliminated the need for extended tracking or expedition mode settings on the inReach Messenger and inReach Mini 2.
Extended Tracking will disable several features of the inReach SE+/Explorer+ and inReach Mini (listed below) to conserve the battery life of the device for tracking.
Bluetooth
Message Listens
Navigation
Log Interval
If any of these options are manually turned on, after Extended Tracking is enabled, the device will automatically leave the Extended Tracking mode.
Extended Tracking does not change or affect the track Send Interval for the inReach device.
While in Extended Tracking mode, the device will go into a "sleep" mode and the screen will appear to be turned off. Tapping the power button will "wake" the device up to be used as normal.
Expedition Mode features for the GPSMAP 66i/86i/86sci and Montana 700i/750i:
Track points are dropped via a smart recording mode that determines the best interval to log based off movement and other factors.
Track log detail will be reduced when the setting is enabled.
Bluetooth connections are disabled.
ANT + connections to Heart Rate monitors or other sensors are disabled.
Using the Expedition mode (with a clear view to the sky) can increase the device’s battery life by days or even weeks.
Expedition Mode allows the user to prolong the battery life of the GPSMAP 66/86i/86sci and Montana 700i/750i. When enabled the screen will turn off and the green light next to the power button will occasionally flash to let you know the unit is still powered on and recording data.
While in Expedition Mode, the device will go into a "sleep" mode and the screen will appear to be turned off. Tapping the power button will "wake" the device up to be used as normal.
Temperature
All devices that use batteries are subject to reduced battery run times in cold conditions. Conditions below freezing will significantly reduce the battery capacity and charging can only occur above freezing.
Connected with Additional Sensors or Devices
Connecting the handheld with a watch will create an additional drain on the battery. Another example would be connecting the GPSMAP 66i/86i/86sci or Montana 700i/750i with a tempe sensor. If the additional sensor is not in use, it a good idea to disable the connection so the handheld is not searching for the additional information unnecessarily.
Expected Battery Life for inReach Products
inReach Mini
Profile
Logging
Sending
Extended Tracking
Battery (hrs)
Connected to Phone (Default)
Off
10-min
Off
90
Standalone, No Phone
Off
30-min
On
575
Connected, Expedition Plan
1-sec
2-min
Off
25
inReach Mini 2
Profile
Recording
Sending
Extending Tracking
Battery (hrs)
Standard
10-min
Not Applicable1
Full Sky View: Up to 336
Moderate Tree Cover: Up to 96
Connected to Phone
High Detail
10-min
Full Sky View: Up to 120
Moderate Tree Cover: Up to 48
Connected to Phone
Standard
30-min
Full Sky View: Up to 720
Moderate Tree Cover: Up to 240
inReach Messenger
Profile
Recording
Sending
Extending Tracking
Battery (hrs)
Not Applicable
10-min
Not Applicable1
Full Sky View: Up to 672
Moderate Tree Cover: Up to 336
2-min
Full Sky View: Up to 144
Moderate Tree Cover: Up to 72
Profile
Logging
Sending
Extended Tracking
Battery (hrs)
1-min
10-min
Off
115
Off
30-min
On
1100
1-sec
2-min
Off
50
Profile
Recording
Tracking
Expedition Mode
Battery (hrs)
1-sec
10-min
Off
35
Smart
30-min
On
225
1-sec
2-min
Off
25
Montana 700i/750i
Profile
Recording
Tracking
Expedition Mode
Battery (hrs)
1-sec
10-min
Off
18
Smart
30-min
On
300
1-sec
2-min
Off
15
Additional information on these settings and how to adjust them can be found in the owner's manual.
My Battery is Still Draining Rapidly
If battery drain continues after making some changes to settings, try returning the handheld to factory defaults and seeing how long the battery lasts on a full charge without pairing it to smartphone again.
If the battery lasts like it used to, then the battery drain would be the result of the choice of customized settings on the handheld, or Bluetooth-connected features.
1Hardware and software improvements have eliminated the need for extended tracking or expedition mode settings on the inReach Messenger and inReach Mini 2.
